Help with purchase decision
dj_shooter
I was ready to commit to the following 7.1 system:
Denon 2809 receiver
6 X Def Tech ProMonitor1000's for surrounds
1 X Def Tech ProCenterr 2000 center
1 X Def Tech ProSub 1000 sub
for approx. $3,200 from Amazon or BestBuy or wherever...
Then I stumbled across a "Custom Entertainment Solution" bundle at 6Ave.com for:
Denon AVR-3808CI A/V Receiver
KEF KHT5005.2 Speaker System (Bundle)
for $2,286
I was looking at the KEF speakers before I settled on the Def Tech's, but this bundle seems like a heck of a deal. What am I missing?
Is dealing with 6ave worth it?
Are the KEF's a significantly lower quality sound?
What would be a good speaker pair to add to the 5.1 KEF system to bring it to a 7.1 system?
Any help would be greatly appreciated.
AVRat
AVRat
Welcome dj, just to confuddle you more, for around $1800 shipped you could purchase an Ascend Acoustics CBM-170/CMT-340C/HTM-200 combo and an SVS PB12-NSD that would definitely outperform either of those speaker systems.
Reorx
Or the Sierra 1's for the front 3, and 4 CBM-170's for surround for $1788. $1874 after s/h. Of which would leave you $400 for a receiver.
The Denon AVR-3808CI roughly costs $1000 by itself.
Getting good speakers though comes 1st before the receiver. Since most keep speakers longer then receivers.
Midcow2
Midcow2
some ideas to consider.
As much as I like Def Techs, I wouldn't go with your solution. Def tech or other I would first set a budget and go along this line:
1/3 of budget - receiver.
2/3 of budget - speakers.
There are lots and lots of AVRs strating as low as $199 and going up.
A very good inexpensive AVr is a Yamaha RX-V363
http://www.amazon.com/exec/obidos/ASIN/B0013ZGOYM/interactiveda8738-20
First I would concentrate on front speakers; that is where most of your sound quality comes from.
If you listed to HT , then a center speaker which provides voice is important. It is also important that the center match the front speakers to maintain timbre ( seamless front sound).
You can add surrounds later; there enhance and augment the sound. They do not need to be as large or match the front and center speakers ( True audiophile purists want every speaker the same fronts,center , surround.s. This gives you absolutely perfectly matched sound but a a considerably higher cost. You approach this with the ProMonitor 1000s but I would look for a larger front speaker).
Later you can add a subwoofer; good brands are SVS and Hsu. An inexpensive ggo starting sub is a Dayton HT120
http://www.google.com/products?hl=en&rlz=1G1GGLQ_ENUS303&pwst=1&resnum=1&q=dayton+HT+120+subwoofer&um=1&ie=UTF-8&sa=X&oi=product_result_group&resnum=4&ct=title
Deteremine your budget then go and audition speakers.
Good luck!
MidCow2
jamie2112
Good deal.......
Pyrrho
Pyrrho
I think what you should do depends upon what you already own. If you are starting from scratch, then, of course, you will need to buy a receiver (or some separates), but if you already have one, I would not recommend buying a new one at all unless you really need it. Surround receivers are a bit like computers, losing their value with incredible rapidity. It is best to only purchase one when needed, as most likely, within a year or so, one will be able to get something better for the same amount of money.
Also, Midcow2 has a good idea in budgeting more money for the speakers than for the receiver. However, at the prices you are talking about, I would recommend a much higher percentage on speakers than on the receiver. I used to run a receiver that retailed for about $600 with speakers that retailed for over $6,000 (including subwoofers, which, of course, are speakers). It sounded great. Because I wanted more features, I replaced the receiver with something that retails for about $1600. Guess what? It sounds the same, unless I engage a new feature that affects the sound. Granted, if I had needed more power, the newer receiver would sound better (it can put out about twice the power of the other one), but I did not need any more power.
If what you want is good sound, put your money in your speakers.
Additionally, when they come out with some new feature in receivers that you decide that you must have, you will still get the benefit of better speakers when you replace the receiver. In other words, great speakers not only are more significant to the sound of the system, they tend to have more lasting value as well.
