Using a older 10" 100 watt Velodyne sub I had in a 5.1 system. I am afraid the SPL level will damage the sub. I had tried so many other "amps" for this application and finally tried a powered sub I had in a home audio setup. It worked great. I want to know the forums opinion of a suitable subwoofer for this application keeping the weight, size, and cost to a minimum. I know the SPL (Sound pressure level) will be high on the sub due to the acoustic bass drum impact. I have really searched for a solution to this application, and the powered sub seems to be the best solution. The PA system is so small for vocals that it is impractical to run the drums through a small PA, so I am left to implement my own "system" in these small venues. What about the BIC models?
