I'm no electrical expert, I get my younger brother to do that stuff, but you need to have your TV/audio stuff on a different circuit. What you could try is to plug your extension cord/power bar into a different outlet (in a different room, you may even have to try several, older houses are bad for this) to see if this eliminates the problem. If it does correct the problem you can switch the outlet (in your TV room) on to a different circuit in your breaker box, preferably it's own with nothing else running on it. It's easy and cheap to do but if your unfamiliar with electrical work get someone who is or an electrician.
It also wouldn't hurt to have an electrician look at things just to make sure all is well.
Oops, just noticed your in a apartment, if this is something new I would report it and have it looked at.
