Long and short of it: got 'suckered' into buying a terrible brand of speakers about 5 years ago for a 5.1 set up in my HT room. Subwoofer blew up about a week ago, not worth fixing. Which leads me here. I'm looking to start replacing all of the speakers in my theatre room, starting with the blown subwoofer. With that in mind, here are my room dimensions, budget etc:
Rectangular room approximately 18.5 ' x 10.5' x 7.5 ' = 1450 cubic ft +/-
Front Row of seating is approximately 9' from the front tower speaker placement
Rear Row of seating is approximately 14' from the front tower speaker placement
Rear Row of seating is 16" higher than the front row via risers I built
Door is at the rear of the room on the right hand side (if facing the screen)
110" screen
Ceiling mounted Epson Projector is (basically) right above the 2nd row of seating
Prewired speaker wiring is at the back of the room
Yamaha RX-A2040 receiver
Right now, I've got the two front towers on either side of the screen. Center channel centered under the screen. Two bookshelves mounted in the corners on the wall behind the last row of seating. There was no prewired place for the subwoofer, so I had it on the floor behind the last row of seating.
As far as my budget goes, I'm looking at 10~20k Canadian, spread out over the next 1~2 years. Ideally I'd like to stay closer to the 10k mark, but going up to the 20k mark wouldn't break the budget (my wife would have something else to say though lol).
As for what I'm looking for, I'm not hung up on any particular brand. I've been doing a lot of research over the past week or so, and there are a plethora of great options out there. Obviously, I'm looking for the best bang for my buck. I'd like to get a 7.2.4 system in there, but the .4 is the sticking point, as I'm not sure how practical it is to get 4 ceiling speakers installed. I was thinking some bipole/dipole speakers hung on the side walls might be the better option.
Anyway, if you've made it this far, thanks for taking the time to read all of that. Any and all thoughts, comments, and advice is greatly appreciated.
Cheers.
}Fear_Inoculum{
