Help with Hook-Up..new TV - old AV recvr
chgo36
I gave my son my old Yamaha RX-V596 AV Receiver for his dorm room. He bought a new LG 42PJ350 plasma tv. The old AVR does not have HDMI. It does have a monitor output to run a S-Video cable but the TV does not have an S Video in? All he wants to do is watch tv using the AVR to run the sound through his speakers. Also wants to hook up DVD.
He is not close so I cannot look at the connections and figure it out......can anyone help us out?? What cables does he need, and where does he connect....thanks
jostenmeat
Just run separate connections. Yes, he'll have to select inputs two times now, once for tv and once for receiver, but it's the best way to do this.
If DVD player has HDMI, then run that to TV, and optical to receiver. Most any component usually outputs everything simultaneously, as shotgun.
If cable/sat box has component connections only, and not HDMI, run those to TV. Run optical/coax to receiver, etc.
It's easy.
markw
To add to the above post...
As stated above, your son should run the best available video from the sources directly to the TV. Usually, for the DVD it will bethe component output. This requires three video connections (red, blue,and green) from the DVD to the TV.
For the audio, the best sound will be obtained by running a digital connection from the DVD player directly to the receiver. This could be either an interconnect with an RCA plug on the ends, or a "toslink" cable, which has a square plastic connector on the ends. Given a choice, I prefer the former.
Additionally, if he wants to be able to use the DVD and the TV with the TV speakers, he can run a stereo interconnect (red/white pair) from the DVD player directly to the corrosponding audio input on the TV. He would turn the TV volume all the way down when he wants to use the receiver.
As for using the TV through the AVR, he needs to run another stereo interconnect (red/white pair) from the TV's red/white audio outputs* to a red/white input on the AVR.
In any case, he will select what he wants to watch (video) on the TV and what he wants to listen (audio) to via the AVR. When he listens through the AVR he should turn the TV sound all the way down.
* Check the TV's manual for more on this.
