Well, my Dad over the past 9+ months has renovated his basement from completely unfinished with nothing but concrete to a very nice looking entertainment room. There's now a bar and a pool table a long with a nice 1080p 46" HDTV. To complete the transformation, I'm helping him get a home theater surround sound setup.
Let me preface this with saying at first he just wanted a *shudder* Bose wave machine. I know, I know. I talked him out of it and told him all of his work would be wasted if he didn't go the correct route of getting a receiver + at least 5.1 surround. He finally agreed. I was hoping you guys, the experts, could help me help him get the best bang for his buck.
Here's what I came up with after a few hours of research and review reading:
Yamaha RX-V665 Receiver
Energy Take Classic 5.1 Surround Sound
Sirius Connect
That put's it right under $1,000. That's his budget but is able to go over if necessary.
But the big thing I am wondering about are the speakers. I know those are quality from everything I've read. But the room layout is what is bothering me. The main need is a quality surround sound experience when viewing movies, TV shows and live sports. But the setup should also be able to fill the room with sound via Sirius while shooting pool.
The issue is the way the room is laid out, it is going to be difficult to fulfill both needs. I will be going over there tonight to create an accurate room layout with true measurements. The walls are drywall and the ceiling is made of removable tiles. Running/hiding the speaker wire won't be a problem. Anyways, I will update this post later with an accurate room layout. After that, will you be able to recommend correct speaker placement ?
Along with ensuring I am getting him quality components, the main goal of this post is to determine:
1) 5.1 or 7.1 speakers
and
2) Correct speaker placement based off the answer to #1.
Thanks so much in advance for your help!
