help with harman kardonAVR235
pan78
I have HK AVR235 and everything is fine except there is no sound coming from the speakers. I tried to reset the microprossesor but still the same thing ( no sound). Dont know what to do, please help.
Thank you
rnatalli
Are your sources properly assigned to their relevant inputs? For example, is the DVD player assigned to analog, optical, coaxial, or whatever? Does the tuner/radio work?
Martiad3
Here's a link to the AVR-235 manual that you asked for in the other thread.
And as rantalli said, go through the menu to make sure you've assigned the sources to the correct inputs. The manual should explain how to do this, but let us know if you're having trouble.
