Help with building 5.1 system
ATLAudio
ATLAudio
$700 is a really good deal on those two subs. I would think that $800-$900 is about the minimum on a single sub I'd suggest.
Get both set up, and run Audyssey. Come back and let me know what the numbers say after you run it. We might tweak it a little bit.
beta1963
Or I suppose I could put a higher end sub like suggested in the current position of the Front sub and move that sub to the rear since it is a wireless sub? I just read that you want to using matching subs in a surround sound setup, or does it matter if one is going to the rear?
beta1963
Ok, I thought it was. They really didn't want me walking out and going to best buy and hhgregg lol, plus they only had half components in stock and overstocked on the others so they hooked me up for having to wait.
Thanks ATLAudio.
ATLAudio
ATLAudio
Only use duals if the same make. Either keep the duals, or perhaps look into a single at about the 800-1000 price point.
beta1963
Since it is a good deal, I will do as you suggest and get the remaining speakers and second sub hooked up in a few days when they come in and check back with the auto settings and a few pics so you can see layout.
thanks
