L
Luiz Vacanti
Hi guys,
Please I will need your advice.
Current I have Philharmonic Audio Affordable Accuracy Monitor as my bookshelf speaker. I like to buy a will center channel to use with them. Also some satellite speakers. And was thinking on buying the subwoofer
Svs sb12-nsd or sb-1000 from SVS.
And for the receiver I'm between Denon AVR2300w or 3300w.
What do you guys think, is it a good budget system? What kind of center and satellite do you guys suggest?
My room is 10x10. What about the subwoofer and receiver any suggestion?
Maybe in the future I will add a turntable too.
Thanks
lavjr
shadyJ
Speaker of the House
Staff member
Looks like a great system, nice choices for the money. I think you will enjoy it.
Pogre
Pogre
If you can get the 3300, that would be my pick. Do you already have the center channel? Dennis makes one that matches up with the AA's. I would also take the nsb over the SB1000.
L
Luiz Vacanti
Thanks I will probably buy another AA and make a center channel.And now with the deal on the 4300 looks like a very good deal.
