Help! When buying VUDU UHD
pewternhrata
Are you using built in app on the sony or external device (amazon roku ect)
Check tv for firmware updates
If using an external box, check the hdmi input has uhd enabled
Walsh1
Walsh1
Nope, just the internal Sony Android operating system. I subscribe to 40 MEGs speed with CenturyLink and it seems to suffice for Netflix UHD and Amazon. And I have watched UHD Movies on VUDU and I think they come through in UHD HDR. Wondering if it's just a bunk message.
nbk13nw
nbk13nw
Could be limited to your bandwith.
Sent from my SM-G988U using Tapatalk
Walsh1
Walsh1
I just did a speed test with Ookla and my speed averages out to just over 45 MEGs. That's plenty. Perhaps I should contact VUDU and see if they have any input.
