Help to choose Legacy SE vs XD
In my city I am limited to Sonus Faber, B&W and Martin Logan. Unfortunately, non of them present the bass in the way that I like.
Are you near Richmond, British Columbia?
I believe there is a RBH dealer around there. The SVT modular tower consists of 2 pieces that stack atop each other to form 1 big tower; the bottom cabinet is an actual big dual 12" dedicated Subwoofer.
https://rbhsound.com/svt.php
Here is a list of other big towers to look into:
http://www.audioholics.com/recommended-systems/towers-of-power-a-look-at-the-best-super-speakers
XTZ also has a big Divine tower if you can find them in Canada.
I may have missed this, but have you ruled out subwoofers?
Or just ruled out traditional subwoofers?
Ruled out Def Tech or GoldenEar? :D
2nd example of Spec vs measurement:
B&W 802 D3 towers.
Spec: Frequency range: 14Hz–35kHz. Frequency response on reference axis: 17Hz–28kHz, ±3dB.
Price: $22,000/pair
http://www.stereophile.com/content/bowers-wilkins-802-d3-diamond-loudspeaker-specifications#7x35gJSgbLlc7gLD.97
Measurement: The Bass Response F3/-3dB response was ~35Hz.
http://www.stereophile.com/content/bowers-wilkins-802-d3-diamond-loudspeaker-measurements#kkviMk2vOKG71DQd.97
In this example, there is also a huge difference between 17Hz (spec) vs 35Hz (measured).
