I need some suggestions. I own an Integra DRX5 AVR and I use both additional zones for outdoor speakers. I had been using Tidal built in to stream Tidal Masters (lossless audio) direct through my receiver which is connected to my network via Ethernet cable (hardwired).
Enter Tidal Connect… no longer will the Built-in Tidal on my receiver connect to the Tidal client. I have to connect through the app. Here are the problems with that: The connection with the Integra is now done through the built-in Chromecast which causes the following issues a) The hires audio will not work through a chromecast device and b) My 2 extra zones will not work. Chromecast only plays through the Main Zone.
I either need some sort of solution to the Integra issue (Chromecast connection) or I need a separate streaming device, but would the Tidal Connect having issues with other devices as well?
