The word diagnostic doesn't yield anything in my search of your manual. There probably is nothing you can do if the soft reset doesn't do anything (the unplugging) and if it won't allow you to do a full/factor/microprocessor reset not much left for the consumer to do. I'd contact Yamaha, probably will need to send to them (or maybe have a local electronics shop look at it if you have one).
