Hey guys, I am currently in the planning stages of my first "HT" build and had some bass specific questions. You can see my main thread
HERE to get a more detailed idea of what I am doing. Quick run down is as follows
Room:
Length ~19.5'
Width ~11'
Height ~8' (just under)
The room has two doors on one side that open to a bathroom/utility room, and a bedroom/office. There are stairs that enter in the back corner that open up to the main floor. There are also windows on two walls, one behind where the screen will go. The floor is laminate on top of a concrete slab, and it is about half underground (41" below grade). Here is a quick drawing of the room.
This is showing EMPTek speakers (E5Bi main and rear surround, E56Ci center, and E55Wi side surround), and SVS PB1000 subs in the front. Obviously I am here about that last little part
So originally I wanted to go with two SVS PB2000 subs, and I was thinking of placing them in opposite corners. So one would be on the front wall straight ahead of the stairs, and other on the back wall opposite the stairs. Well as we know, those are some big subs, so I moved them both to the front so I didn't eat up all of the room behind the bar area. Then once I started playing around with the screen to get an idea of size (still not decided 100%) I realized a new problem of the subs being in the way of the motorized screen.
SO since nothing has been done, or ordered yet I figured I may as well try and sort this out as much as possible now. I am trying to determine two things.
1. What would be ideal location of each sub? Is there a way I can experiment with 1 sub (different make/model) in an empty room to help this?
2. What sub(s) should I go with? I am very partial to SVS, and would be hard to convince to get any other brand, but I am open to any they offer within budget. Budget would be $1,500 max right now.
This will be used almost exclusively for movies, and I like my bass A LOT! I am really looking for even, hit you in the chest, earth shaking bass.
Lets hear what you all think!
Thanks,
Sean
