Thanks much for the quick replies. I'm surprised and how easily this was to mess up... I didn't connect the thing live, I just turned it on and zap. My Outlaw preamp seems dead. I'll have to test the turntable preamp on another receiver, but it's super quiet throughthe analog port and I don't want to run it that way.
I see this unit does have a reset option in the set up menu. That will return the unit to its factory default settings.
Before that, I would ascertain if all sources are now quiet. So play a CD through it, and see if that has changed. If so, do a reset.
If that does not work call Outlaw Audio at (866) 688-5297.
I note these units only carried a 30 day warranty. Let us know how all this goes, but in general, after sales service is generally poor to non existent across the board these days, which is totally unacceptable.
I have looked for a service manual and there isn't one, and no circuit available either. That is typical. This is pretty much an industry wide problem and totally unacceptable.
Your mistake was very understandable. If it has just sent the unit into some type of protection mode, and a reset resolves it that is fine. If however what you did has done hardware damage, then that is awful design. There is way too much of that around these days.
