HELP!!!! Purple & Green lines on my Samsung LCD TV?
marquita188
i woke up this morning(3/10/11) turned on the TV, and saw these lines going up & down on the screen. how can i fix this?
i think the sub was too close the TV.
how far away do the sub have to be away from the TV?
receiver: onkyo HT-R380 HT-S3300 HTIB
subwoofer" powered active Yamaha YST-SW216
HDTV: samsung 26'' LN26A450 LCD
cable box: comcast Motorola DCT6412
jostenmeat
You've got to do a lot better in describing your setup, the connections, and what you've compared this to if you want any help.
Does this happen on all sources? If so, are they all connected to one receiver?
If both the above are true, have you tried a different input on the TV?
Or instead have you tried any of the culprit sources directly to the TV?
(I shouldn't have to be wasting my time asking you these questions, because I don't get paid for it!)
The first thing I'd hope to suspect is the STB.
If it's your TV, ruh roh. My friend's Samsung LCD TV just died this week, it was like $2k and it didn't even last 3 years. I convinced her to use her Costco Amex card for the replacement TV since that gives her up to three years in free warranty, even if I myself would have risked much less warranty for a flagship Pana plasma.
marquita188
WOW!! ALL I WANTED WAS SOME HELP!!
this just happen today, like i said. i have hook up thur RGB Component both the cable box & TV. stb? what's that? of course the TV is mines. ruh roh? um OK. i brought it in November of 2008.
AVRat
AVRat
STB = cable/Sat box
Try going straight from the STB to the TV. It may just be a cable/connection issue, but you need to do some troubleshooting to see where the problem may lie.
marquita188
STB = cable/Sat box
oh, OK i did that, it works great again.
