ROADSTAR said:
Actually I thought I deleted it from the initial spot.
No, but I see you did delete the text from it immediately after this post. That's not really in the spirit of this forum.
But, that's all right. The answers so kindly provided to you, and the questions asked, still remain. I do see where you deleted all your responses to them, which had little to do with what was sugggested.
You've been given several options to try and asked several questions. Have you done anything about them? Did you even tyy to implement them? If so, why no reporting of results?
...or did you just blow off all the advice offered you, hoping for a magic answer to make all your problems disappear?
hint: You might want to ruminate on some of those answers you've already received. If, as you say, it works well in the HT mode, it's a most likely working correctly in the music mode and, most likely it's a user error or a lack of understanding of the functions being used.
