Get the 2309, it's a better value for you.
Thanks a lot Lordoftherings!!
That's what I was thinking in the first place!
I can get also Denon 2808 for 1250$ and am thinking of getting that.
Is 2808 better then 2309 and worth extra money even if it doesn't have dynamic eq?
Thanks a lot for your answer because I'm all torn up over here
Well, it all depends, they are pretty much the same receiver.
Some people like Audyssey Dynamic EQ, and others don't care for it.
Plus the 2808 has preouts for all it's channels, which the 2309 does not.
So, if you want to add external amps later, with the 2808, you can.
So, if the 2309 is a good fair chunk of money less than the 2808, well, go for it then. Because it seems so. Not only the 2309 is cheaper, but it is more recent with extra features. And the power difference between these two, is minimal at best. And me, I don't need preouts, I never used them anyway.
One is not better than the other one. Me I'll pick the one that cost less, unless there is a small difference in price, then I'll pick the 2808.
I don't see the big jump in price worth it for the 2808.
So, get the 2309, and try to get it for lower than $980, just like I said in my previous post. Offer the guy $900 or so. And check other dealers in your area for a better deal.
It's all up to you now, with the features that you can use best, and the best value, money wise. For me, it's the Denon AVR-2309ci, in your particular area.
Happy shopping,
Bob
