help on deciding small but powerful speakers
HTspeakers
Thanks for the recommendations..I'll try the svs speaker system.
do they sell only online or is there anyplace to audition their speaker system ?
cfrizz
SVS only sells online. But they give you 30 days to try it out. If you don't like it you can return it.
mazersteven
mazersteven
Like cfrizz said. SVS is an internet only company. They produce quality speakers and subwoofers. There costumer service is excellent, and most times exceeds your expectations.
Plus I wouldn't have recommended then if they sounded or performed badly. :D
Good Luck
F
flippo
Mirage Omnisat v2 Satellites
The Mirage omnisat v2 satellites are wall mountable and sound excellent with a very wide soundstage. Do need subwoofer but looks like you would be getting anyways. Crutchfield has them. Another option is the mirage nanoset system which goes for 799$ crutchfield also sells. Check them out before deciding.
