These arguments are based on a power amplifier attached to a tweeter, which is not the case.
Amps can clip on musical peaks if they cannot supply the power.
Clipped peaks produce dynamic compression. Some will turn up the music because it is not loud enough until it sounds compressed.
It is non-trivial to determine if an amp has is clipping during peaks when listening "loud". 80 DB is too loud to some.
I cannot listen to distortion at 80 DB because it is too loud. By dynamic well recorded music is a different story.
Bottom line, an amp should be sized so that power compression does not alter the sound. It should not clip.
There are companies that provide tremendous power and reasonable prices so enthusiasts might oversize their amps
Amps that handle peaks and do not clip, don't get stressed or hot will last a good long time.
Now, where could I find an enthusiast who does that...
- Rich
