Thanks man. Yes, I just responded to your email. I've been out running around this morning troubleshooting the issue and now it is fixed. Many thanks LAB3 for your email suggestions, patience and support on this issue.
BTW, as AcuDefTechGuy later stated.......it was the HDMI cable.
As LAB3 suggested, when I tried hooking up the blue-ray directly to a TV in the bedroom without the AVR it initially reacted the same way with no signal. I went out and bought a new HDMI cable and then it worked. I then took it back out into the family room and connected it back up to the AVR using the new HDMI cable and everything works like a charm!
TV, Tuner, iPod, Cable/Sat, Blue-Ray+CD music. Things are great again!
Thanks guys!
