HELP NEEDED WITH T-LINE SPEAKER BUILD
johnny45
johnny45
HEY I COULD USE SOME HELP CAL'ING THE PORT SIZE AN LENGHT FOR A 10PLB76 WOOFER TLINE BUILD IVE GOT TWO
BOARDS THAT ARE 1.5IN BY 11.25IN WIDE BY 8FT LONG THAT I INTEND TO USE FOR THE FRONT BACK AN INTURNAL WALLS
AN ONE .75IN BY 4FT BY 8FT MDF TO USE TO MAKE THE SIDES SO THAT IN MIND SO IF ANYONE COULD YOU HELP ME WITH THE DESIGN
FYI I DONT MIND A TALL BOX JUST NOT A SUPER DEEP BOX PREFURABLE NOT MORE THEN 14INs I ALSO PLAN TO FEED IT
200 WATTS SO FACTOR THAT IN IF YOU WOULD THANKS
THIS BUILD IS FOR MY SURROUNDS AN MY FRONTS I PLAN TO BUILD SIX TOTAL OVER TIME.
PLEASE FORGIVE MY CAPS THE KEY NO LONGER WORKS RIGHT ALONG WITH SOME OTHERS ON MY KEYBOARD
A PM has been sent that will sort you out.
johnny45
johnny45
THE INTURNAL SHAPE IS A TOTAL 10.5IN WIDE 4IN HIGH 72IN LONG
THE OUTER FRAME IS 39IN HI BY 12IN WIDE BY 11.25 WIDE
FQ CURVE IS FROM THE SPECED DIMS OF THE PURPOSED CABNET AN DRIVER 10PLB76 WOOFER
AN THE BROWN LAYER IS TO REPERSENT 1IN THICK ACOSTIC FOAM
WHAT DO YA'LL THINK IN SHOULD IT HAVE MORE OR LESS AC FOAM
AN IS THE DRIVER POSITION OK
