Help Needed to Choose the appropriate AV Receiver compatible with my existing speakers
Phase 2
Phase 2
You should be ok, just don't get crazy with the volume you did say the speakers are used.
JerryLove
JerryLove
I got some used Paradigm Monitor 7 v.3 floorstanding speakers, center CC-370 v.3, and pair of Mini Monitor v.2. I wanted to test them out but I only have a Sony DAV-BC150 system at home. Can I hook up the speakers to that system? Any danger of damaging the speakers? Do I need to keep it at low volume only? Speaker wire is super thin, is that a problem?
The speakers are 88db (anechoic) with 130 max power (I'm assuming sustained); so you can safely run them to 108db @1m.
Assuming sustained: that's quite loud. If that's peak: then there's a little more care needed. That said: crossover to a sub and you get a bit more leeway.
KEW
KEW
Start with the volume low and listen carefully for distortion as you raise the volume.
My fear would be clipping from a weak (or not capable of handling the impedance of your speakers) AVR.
It might be wise to simply test one speaker at a time (still listening for distortion and backing away if your hear bad sounds) since the AVR should be more cable with only a single speaker.
Some of these HTiB can be pretty weird with the amp section designed for 16 ohm speakers... or more designed for 4 ohm speakers like a car stereo. When the manufacturer knows exactly which speakers will be used (as in an HTiB), they can get away with cutting cost by designing the amp specifically for those speakers.
You might also check Craigslist for receivers, there are some good deals to be had there on AVR's that don't have HDMI connections (assuming your TV and DVD player don't require HDMI). I've seen some good 5 channel units going for $40-75, and that might be worth holding you over if you don't expect to (or would rather not have to) get funds for the 3400 too soon.
The good thing about a $50 receiver is, as long as it works, you should pretty much be able to sell it for about the same - it was already well used and your having it for 6 months won't depreciate it very much.
If you want, post a link to your local Craigslist and we can see what looks good.
RG7000
Thanks for all the help. I hooked them up and have not heard any distortion at low and moderate volumes. It's plenty loud for me at 75 dB, so I didn't really need to test it more than that. Each speaker sounds good.
I have lots of $50-$100 used receivers for sale in our area, Chicago and suburbs. Sounds like a good idea to just get an older, non-HDMI for now to hold me over. Probably Christmas or Black Friday at end of year will have lots of electronics and receivers for big discounts.
