I have a 60" Sony LCD RPTV that sits on Sony Glass TV Stand (SUGW12).
The set up looks like the one in the picture below :
The bottom shelf in the TV stand is the only place where I can fit the CLR 2500. The bottom shelf height is around 8.5" and the height of CLR 2500 is 6.75". The CLR 2500 has 2 5.25" midrange drivers on the front and an 8" powered sub wooder on its top.
Given that :
1. After I place the CLR 2500 in the shelf the that gap between the top of the speaker and the top shelf is less than 2",
2. The CLR 2500 has a powered subwoofer on its top and
3. The stand is made of glass,
is it still a good idea to place the speaker in the stand ? If so, what else can I do to reduce the reflections / vibration for the glass ?
One alternative I was thinking was to place the speaker on the top of the TV. But I am not sure if I can do that since the TV does not a large flat top, tapers on the back and the CLR 2500 is 23-1/2" W x 6-3/4" H x 14-1/16" D and I am sure it is quite heavy because of the two 5.25" and one 8" drivers. Are there any platforms available to accomodate this kind of a big and heavy speaker on the top of a TV?
What are the other options / suggestions to solve this ?
Also, what are the options if I use CLR 3000 instead of CLR 2500. CLR 3000 is even bigger (25" W x 8-5/16" H x 16" D) and heavier with a 10" sub instead of 8".
Sorry for the long post and thanks for taking the time to read it.
Any help is greatly appreciated.
Thanks
Arun
