Hey everyone,
I’ve got a setup of
5 Technics speakers running through a
Technics SA-EH780 system, which includes a
stereo tuner/amplifier, sound processor, CD player, and
cassette player. Alongside that, I’ve got
2 JBL GTO speakers (originally car speakers) that I custom-cased and connected to a
Yamaha AV receiver. I want to run
all 7 speakers together, with the audio coming from my PC.
Here’s where I’m stuck:
- Connecting the systems: I assume I’ll need to connect the Technics stereo amplifier to the Yamaha receiver, and then have the Yamaha connected to my PC. Does that make sense? Would I need an RCA switch to handle the inputs/outputs since I think that there is no more left?
- EQ Control: Will my Technics stereo sound processor (basically an EQ) apply EQ to all the speakers if I’m using the Yamaha receiver as the main control unit?
- Should I use the Yamaha as the main control unit?
- Sync and Quality Concerns: Should I expect any sync issues or inconsistencies in volume or sound quality by combining these two systems? I’d rather not lose any audio quality, so I’m avoiding low-quality RCA switches—any recommendations for something reliable?
- Sound Card: I’m also wondering if it’s worth investing in a dedicated sound card to get the best out of this 7-speaker setup, maybe it can add quality? Or is my current MSI X470 GAMING PLUS MAX motherboard will be enough.
Any advice or recommendations would be awesome. Thanks!
Note: Dont worry about the tweeters on the JBLs I will solder them back on.
If you need any more pictures then sure because i couldnt fit in the JBL speakers (10 pictures max and i have 15)
