Help me understand this new Dynaudio
The cabinet edges shown on the new Dynaudio, The Bookshelf speaker. This was shown at the Munich Show.
It is just a stylistic choice. It might inflame the edge diffraction brigade, but I can assure it will not affect the sound one wit.
mono-bloc
mono-bloc
What is there to explain, It's just a bog standard bookshelf speaker, No doubt some self appointed expert will come along and offer a highly technical reason for the side overlap in the design, which will mean absolutely nothing.
Eppie
Eppie
I saw a Youtube video where they asked the rep about the cabinet design and he basically said the same thing that TLS Guy said. It's just a stylistic choice aimed at the designer home/office market.
Swerd
Swerd
I am neither a member of the edge diffraction brigade, nor a self-appointed expert on this subject. But there is evidence that rounded over (¾") cabinet edges make for slightly better measurements than cabinets without round overs. Note the peaks at 4 kHz and the dip at 7 kHz.
A Tale of Two Cabinets
Dennis Murphy does not claim that rounded over cabinet edges make big audible difference – only that it can be measured. If rounded over edges are easily done, why not do it?
Once you put the grill on it makes no difference. You won't hear that difference anyway, and I have stopped doing it.
mono-bloc
mono-bloc
What a load of cod's wollop. You really should seek treatment
And all the so-called measurements won't tell you what they sound like.
Easily done with solid wood, but not as easy with veneer.
