Help me to match a amp with a def tech Mythos five system
  • Thread starter arnaldinhoalves
  • Start date
arnaldinhoalves
Hello!!!
I'm a newbie here, and I want to ask your help to find a amp that could work well with my future Def Tech Mythos five soud system.
Thank you for your help.
dapack69
dapack69
A regular amp or a A/V receiver?
Need more information as what size the room and current setup is.
arnaldinhoalves
Actually I think an A/V receiver could work better for me.
My room haves 18m2 and my setup is:
TV: Samsung UN55C6500
Blu-ray player: Samsung BD-C6500
And I'm thinking about to buy a mythos five gem system from definitive technology, but if you guys could suggest me any other speakers system on a budget of 2500$ (more or less) I'll be very thankfull.
Thanks for your help
AVRat
AVRat
http://www.definitivetech.com/Products/products.aspx?path=Home Theater Speaker Systems|On-Wall Systems&productid=Mythos Gem System &hometheater=1
If this is the system, I’d skip it simply because of the sub. Where do you live since you’re using metrics? We need dimensions (L x W x H) for the room to size the sub appropriately.
If you’re in the U.S., for around $1800 shipped you could purchase an Ascend Acoustics CMT-340/CMT-340C/HTM-200 combo w/stands and an SVS PB12-NSD which would knock the socks off the DT system.
This could easily be powered by a Denon 1910.
arnaldinhoalves
I live in Panama, and I don't know if I an find Ascend Acoustics here. But I'll look or.
The dimensions of my room are:
L : 4.5m
W: 4.2m
H: 3m
I was thinking about an onkyo TX-SR607 or a Denon AVR 890, what do you guys think about this two?
arnaldinhoalves
Ok... I´ll contact them.
Thank you very much for all your help.
arnaldinhoalves
Thank you very much for your help... I just bought today an DENON 1910 from amazon.
