AVRat said:
No worries, skip what I said about the 7004s. The X-overs for the Mythos should be 80Hz as you previously stated. You’ll need to check the configuration settings to see what the auto-setup came up with. All speakers should be small w/80Hz x-overs. Let us know what it set the channel levels at, to see what adjustments might be made.
If you’d like to start from scratch, initialize the processor pg. 42.
To add to AVrats' post, the Audyssey auto EQ on the Denons almost always sets the speaker size cross overs incorrectly. You have to go into settings and manually correct it each time you run auto EQ. I agree with the 80Hz crossover and all speakers to small. There is a seperate crossover for LFE, double check it to make sure it's set to 120Hz. Here is an FAQ from Chris at Audyssey. If you read more of that thread, note that Chris and I are now on good terms after some stupid posts on my part.
http://www.avsforum.com/avs-vb/showthread.php?p=7969145#post7969145
Here is a list of tips based on several discussion in this and other forums about MultEQ. I will add to it from time to time as new questions come up. Some additional information can also be found on the Audyssey website.
CTO, Audyssey Laboratories
Microphone Placement
• The microphone has been calibrated for grazing incidence and so it must point to the ceiling during calibration. Any other orientation will produce incorrect results.
• The microphone response has been calibrated to match (on average) the response of an industry-standard ¼” instrumentation microphone. It is critical to use the microphone that came with the receiver and not one from another model that may have a different calibration curve.
• It is also important to place the microphone on a tripod or other stand so that it is at ear height. We strongly recommend against holding the microphone in your hand because this can give rise to low frequency handling noise that will cause the MultEQ filters to compensate by cutting those frequencies. Furthermore, it is not recommended to place the microphone on the back of the couch or recliner. If a tripod is used, care must be taken to ensure that the microphone is placed at a height just above the seat back so that reflections from the seat do not cause problems at higher frequencies.
• The first microphone position is used to calculate the distances to each loudspeaker and subwoofer and set the delays. It is also used to measure and set the trims. So, it is important to place the microphone in the main listening seat for the first measurement.
• MultEQ measures the background noise level in the room before playing the test signal from each speaker. For the measurements to be valid, the signal to noise ratio must be above a certain threshold. If it is not, the test signal from that speaker will repeat at a higher level. If the noise in the room happens to be higher during some of the speaker measurements, then the test signals from those speakers will sound louder than the test signals from the other speakers. This does not affect the calculation of trim levels. If the room noise is too high even after the test signals increase in level, then an error message will be displayed warning the user that measurements can not be completed.
• After the first position is measured, MultEQ measures other positions in the room around the listening area. These do not necessarily have to be in each individual seat. The idea is to capture as many points around the listening area as possible so that the acoustical problems that affect the quality of sound within that area are minimized.
• For example, we recommend taking 3 positions on the couch facing the TV and then 3 more positions about 3 feet in front of the couch and parallel to the first three. Measurements up against the back or side walls should be avoided.
End of Part One.
