Hi everyone,
I'm looking at buying a receiver. I was originally going to go with the Yamaha RX-V1800, but then I found out that you can't play digital sources in zones 2 and 3, which is something i need it to do. So here are my requirements:
- 100W or more per channel (7.1)
- 2nd and 3rd Zone (must play digital sources, 2nd zone can be the extra 2 from the 7.1, I only use 5.1 in my living room)
- It needs to be able to have HDMI in for the video & SPDIF for Audio, so that I can hook up a computer with DVI to HDMI out plus the Audio in the SPDIF format
- Total of 4+IN and 1+OUT HDMI
- A nice On-Screen Display from the HDMI OUT (The receiver will be in a closet, so the OSD shows me what is going on.)
- RS232 would be really nice, but not an absolute must
I think that's about it. Thanks a lot for any help, I really appreciate it. Oh before I forget I want to spend under 1000$ if possible, but I wouldn't mind buying it of eBay, for example the RX-V1800 I found for around 800$.
Thanks!
