Help me decide on the best setup
O
okfireman
I have been looking and posting for awhile on here and believe I have finally decided between three definite choices. All are similar in price and would feature the same setup. They are all 3.0 setups and will have a pair of bipolar or dipolar surrounds added later and a descent sub. My room is approximatly 12 x 14 with standard size ceilings. I watch all 40% movies 50% tv and 10% gaming. I want them primarily for Home theater use watching blu-ray movies. They probably wont be turned on much during tv watching but will be for gaming. My three choices are these:
1) 2 Infinity p362's and a Infinity PC350.
2) 2 Polk RTI8's and the matching center for these.
3) 2 Energy C500's and a c-c50.
jamie2112
Have you listened to any or all of them? What is your ear telling you? I myself would want to hear all of the choices you have listed. Out of the 3 my choice would be the Infinitys. You can add some more insulation to the 362's and lose some of the cabinet resonance resulting in a much better sounding speaker.What is your price point for this HT setup? The C500's are a great speaker as well though. I like the smooth tweeter sound from the Energy's much more than the harsher Polk IMO. I may have spoke too soon and may go for the Energy over the Infinity in a shootout. Again have you heard them?
O
okfireman
Unfortunatly no I have not heard any of them. There is no where to audition where I am and the only places to go are the big box outlets that dont carry these lines. My budget is around $400 to $500. I plan on adding in some descent priced bipoles for not to much and would like to add a sub so if money can be saved and allocated that way that would be awesome but I dont see it happening. Either way I dont plan on running a huge sub with these because I am already stretching my budget way out. So some bass would be nice out of these but not neccesary because my room is small.
