brian32672 said:
Not the exact words no affect but please reread your #21 post.
You should re-read post no. 21 because the only thing I stated in post no. 21 was my impressions(s) of modern 3 cards vs. a specific integrated video soluiton and the Matrox card, and these had nothing to do with PCI, which seems to be getting mixed into the subject matter here.
Deceptive certainly was not my intention. Yes it relates as well as gpu speed. I do have one more link for that issue as well. But no I am not going to give it to you. You go ahead and keep telling people that all they need is a PCI card with minimal bandwidth and that it is certainly not needed over their current PCI-E. (If those are not your exact words - they are very close - and yes I am still talking about 2D)
At this point, I suggested a PCI card to someone who wanted an inexpensive high quality 2D solution. I have not found any evidence to support that a PCI interface would signifcantly hurt normal 2D use(s). When I asked you for substantiation when you claimed the contrary, you seem to get very upset, for what reason(s), I don't yet know.
CAN YOU READ???? All test were better once they hit 1600x1200
I am just curious on your first post - Did you not say that you use your card exclusively at 1600x1200? So I am assuming since all tests (in 2D) did better in 1600x1200 that this does not apply to you.
Clearly either I don't get it - or you don't.
1. You provide no coorelation of how this perceptually affects real-world uses(s). I would go on, but MDS's post already summed up the issue for me in his last post.
2. The differences: Office Bench 2001, Matrox was 4 percent slower at 1600x1200. Video overlay was equal with both cards at 1600x1200. Officebench index test later in the review, the Matrox was about 8 percent slower in 1600x1200. Not exactly what I would consider significant differences.
Let's assume that the Nvidia card I just tried had at least equal performance, or even better 2D performance as compared to the *winner* in these tests at your link. These marginal differences do not warrant me using a worse quality video card(fuzzier), nor do they warrant buying a much more expensive card(to gain the marginal 2D performance difference and keep the 2D video quality/clarity at the same time). The differences were small enough that I did not notice any difference(s) in actual use.
-Chris
