help low pass filter design
reddevil6
can anyone help me design a low pass filter for a sub i found but the inbuilt amp was fuucked so i hooked the driver up to a old amp all i need now is a filter.
i want the cutoff @ 200 hz
its 8ohm
its 8ohm
200Hz isn't subwoofer territory (it should be crossed over lower than that). What amp are you using? You want the crossover before the amp, right?
reddevil6
I olny said 200 hz cos thats what this subs cut off was when it was hooked up to its ordignal inbuilt amp.
the amp is a old JVC A-K100 this system im just putting togeather for the shed for now with a couple old JVC 2 way speakers hooked up to a diffrent amp than the sub.
Um do i want it before the amp? i was just gonna put the filter in the sub box amp goes to the filter and the filter to the speaker.
