Need some advice. I'm setting up a HT for the first time (7.1), and my room is definitely less than optimal. Pic below is what I'm thinking of doing.
(Since I'm new here, the forum won't let me post an image or link, so here's a 'link' to my picture. Perhaps if someone could be so kind as to insert the image in their reply??)....
i14.tinypic.com/7wj20eg.jpg
The dimensions of the room, the fireplace, the sliding glass doors, the garage door, and the "half-wall" separating the family room from the kitchen are all obstacles to creating a great HT environment.
My plan is to put the TV (Samsung 46") in the corner, to the right of the fireplace, at a bit of an angle towards the couch. It has to be at an angle anyway since there's just 3' on either side of the fireplace.
Receiver is a Denon AVR-2308CI, if that matters.
I haven't found the ideal stand to put the TV and components on/in yet, but I'll be looking for something that allows me to put the center speaker (Axiom VP150) just below the TV.
Because of the tight space for the TV, options are limited for front speaker palcement. Shown is what I have in mind, with the speakers (Axiom M22's)living just below the right and left edges of the TV. Would it be better to put the left front to the left of the fireplace to get more spacing??
Subwoofer (Axiom EP350) might possibly go behind the TV, but not sure if the TV and stuff will be too much of a blockage (?), so I've been thinking it could go the left of the fireplace as shown. One better than the other?
Because the couch is against two walls, the surrounds (Axiom QS8's) have me concerned. The side right will be pretty much directly above the right end of the couch, and the side left will be 3-4' from the couch. What I'm showing, in purple, assumes the side R/L wall-mounted using Axiom's wall mounts that allow me to angle/tilt them. Because the couch is against the right wall, I'm thinking they'll need to go quite high on the walls, up near the ceiling (~8'), just to get some distance to the listener.
I am thinking I will mount the rear speakers on the ~9' ceiling using Axiom's ceiling mounts a bit behind the couch (so they'll technically be in the kitch eating area), angled down toward the couch.
What do you think? Is this going to work? Is there a better way? Is 7.1 even worth it for this layout, or should I just ditch the rears and stick with 5.1?
Any advice would be appreciated.
Thanks!!!
-Steve
