I believe PENG is right. All of the Sony BD players
I have looked at had SACD, but I am not sure it is automatic.
In store, just look for the oval SACD (it says "Super Audio CD" under the oval) symbol like below, just to the right of the Bluetooth icon:
With a background in woodworking and soldiering, I think DIY is a pretty good option for you to save a little money.
There is a lot of overlap with this sub-forum, but you may want to post with a budget and query for suggestions on good DIY options on the AH DIY sub-forum here:
https://forums.audioholics.com/forums/audio/diy-corner-tips-techniques.22/
If you have any insecurities on your skill level, you might consider building a couple of smaller (less expensive) surrounds before the mains. There is also the option of buying the crossover pre-built on some of the designs.
