HELP!!!! I'm a New ONKYO RECEIVER Owner.
marquita188
my speakers sounds kinda tinny, how can i fix this?
speakers are in my bedroom it's 13x17.
also i can't seem to get the receiver to work with my cable box, TV, or DVD recorder.
receiver: onkyo hts3300
subwoofer" powered Yamaha yst-sw216
HDTV: samsung 26'' LN26A450 LCD
cable box: comcast Motorola DCT6412
DVD recorder: Panasonic DMR-EA38V
sholling
sholling
I'm trying to understand. Do you have a HT-3300 (home theater in a box) HTIB or just the receiver from the HTIB?
That receiver does not support video upconversion so how are you connecting it to the cable box and the TV? You can go HDMI from the cable box to the receiver to the TV, or you can use component video for both but you cannot use component from the cable box to the receiver and HDMI from the receiver to the TV.
For the audio have you run the auto setup?
marquita188
htib, dvi(cable box) to hdmi(tv), how do you do that?
BoredSysAdmin
BoredSysAdmin
HT-3300 doesn't have Auto setup. OP could try to enable Audyssey DynamicEQ (see manual on how to)
I'd to and spend about $40 buying (or borrowing) RadioShack SPL meter to make sure all levels matching and setup correct speaker distances .
marquita188
oh OK. but i already have those choices on.
sholling
sholling
DVI to HDMI cable to the receiver and HDMI from the receiver to the TV should work for video but you still need to connect the audio somehow, probably using an optical cable and then set the receiver to look for cable audio via the optical connection. This is all in the manual.
marquita188
yeah tried that but it didn't work, signal kept going out, the screen would turn blue, picture would stay about a second then go out again.
