HELP! Dvd player can't read video disc
Sue
I purchased a Pioneer system last year. The dvd player is built into the receiver. I put in a dvd and it says no disc. Does anyone know what's making this happen? I just bought a cleaning disc and it didn't help. Will it be expensive to get fixed? Any responses will be appreciated.
Vancouver
Vancouver
Hard to say exactly what the problem is, but I can say that many times its not worth repairing the unit inless its under warrenty. How much did you pay for it?
rgriffin25
rgriffin25
Moderator
Sometimes a good cleaning will remedy your problem. If you do it yourself you can save some cash. If that doesn't fix your problem it is likely one of two things. Either the motor that spins the disc is bad or going bad. Or the laser assembly will need to be replaced. Neither of which should cost more than $150 to replace with labor costs. There are rare occations where the laser assembly is very expensive.
Pioneer's warranty on DVD players is 90 days labor and a Year on parts. So you may only need to pay for labor.
