Help choosing wall mount for Martin Logan XTB100
  • Thread starter Thread starter Altyros
Altyros
Altyros
May 10, 2023
30
0
6
39
Hello,
I am looking for suggestions for wall mounts to accommodate my ML XTB100 bookshelves, I saw wali brand that supports 55lbs and mount it!. However I would like to know what you are using and or what you recommend. Clamp mounts seem the way to go but I will not drill a hole in the cabinets.
In a search of images of that speaker I find no built in mounts that speaker provides. You can drill various mounts into the cabinet if you have the will, but can affect resa;e if that's a concern to you. You can install threaded inserts into the cabinet, or simply screw into it (again, depends on resale if that' a concern, but it's not a particular issue for audio if reasonably executed). There are mounts like these that simply grip the cabinet and don't require something in the cabinet particularly, altho that's not a bad way to go otherwise, try these for non-invasive mounts https://www.crutchfield.com/S-TksT3HepOqe/p_121AM40B/Pinpoint-AM40.html
