Plasmator
I need a little help choosing one of these HTIBs. How to tell which is the best of the lot. I have 2 sources - DVD & HD Rec/PVR.
Samsung HT-TX75
"hxxp://vvv.samsung.com/ca/products/hometheatres/hometheatres/ht_tx75txac.asp"
Pioneer HTP-65HD
"hxxp://vvv.futureshop.ca/catalog/proddetail.asp?logon=&langid=EN&sku_id=0665000FS10088260&catid="
Yamaha YHT9505XM
"hxxp://vvv.yamaha.ca/av/Hometheatre/YHT9505XM.jsp"
mazersteven
mazersteven
Do you have to do HTIB? You can obtain much better sound quality with separate components. What budget are you working with? Any restrictions?
Welcome to Audioholics
Plasmator
There is a budget .. sort of ..
I was looking at about $500. Those HTIBs are on sale :D.
The Yamaha YHT9505XM seems like a good receiver - 90Wx6 , powered sub, optical and lots of inputs at the back. But the total power is only 540 compared to the 1000/1200 for the other two receivers.
Separate components would be sweet. The problem is knowing what to look for in a receiver and speakers.
Maybe you can have a look at the BestBuy and FutureShop sites. If you don't mind.
BestBuy
hxxp://vvv.bestbuy.ca/catalog/dept.asp?logon=&langid=EN&catid=20303
FutureShop
hxxp://vvv.futureshop.ca/catalog/dept.asp?logon=&langid=EN&catid=10
mojo_13
Are you going for 5.1 and a reciever? Like mazersteven said if you can do seperates you will be more satisfied I think. I just upgraded from a htib to a polk system with a H/K avr and only broke the bank for 470. I added a Bic H-100 sub but there are cheaper subs out there that will work. So I'd say if you could raise the budget by $100 or even just save and wait to buy certain pieces you will be alot happier with your purchase.
Plasmator
Maybe 7.1 in separate components
I did some more looking around in the stores today. Decided to go for a 7.1 Receiver with at least 2 year warranty. The Yamaha models look pretty good and maybe Polk speakers
Yamaha HTR6090B
hxxp://vvv.futureshop.ca/catalog/proddetail.asp?logon=&langid=EN&sku_id=0665000FS10080050&catid=
Polk RM10FS
hxxp://vvv.futureshop.ca/catalog/proddetail.asp?logon=&langid=EN&sku_id=0665000FS10093376&catid=
