if i use one out the outside walls of the box as part of the port, i would just round off the exposed edge inside the box and leave the outside wall alone right? also back to the port, just to double check, i subtract all the wood used to make the port, and all the internal braces, and however the airspace inside of the port is considered to be a part of the internal volume and is not subtracted?
also how do i find the volume the drive takes up?
![Eek! :eek: :eek:](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
thanks again for helping me!
