I've had a JBL 12" subwoofer (PB12 I think is the model #) for several years now, always loved it. A couple months ago, I noticed that the volume had to be up pretty high to keep the subwoofer from going into standby mode (green light on front turns to red light when there are no sounds for awhile). Now, no matter how loud I turn up the receiver, the lights on the front of the sub just flicker back and forth between green and red, and the sound that comes out is very static-y, and just sounds broken.
I'm not much of an electrician, and I was wondering if there's anything I can do to check for problems with this sub before I spend a couple hundred more to get another one since I'd hate to spend all that money for something that could be a loose wire, and atleast something easily fixed.
Any help is greatly appreciated and I can supply any info that might help.
