I have a mix of several receivers, amplifiers, etc. but I know little to nothing...just the bare bare bare basics!
I need help to be able to determine if I have duplicates or almost, of something, or if xxxx if more complete than xx or better/worst, or if it's not worth keeping also because the xxxxx that I have is all I need instead.
Ok, so I started with this Sansui Ta5900...I looked all over the internet trying to find info about the SANSUI TA-5900 STEREO RECEIVER with INTEGRATED AMPLIFIER to no avail...but found about the MS5900 instead (that is part of this system).
AC 120 Volts 60Hz
Is 60Watts...75VA, speaker impedance 8-16Ω (front and surround)
Has a flat cable "system control" for CD/Cassette Deck
VCR/AUX, and Antenna FM/AM 300Ω-75Ω-Loop
On Front reads: SANSUI SYNTHESIZER TUNER...has 24 Memory presets with Auto search tuning
Bass Boost/Surround, and (if I had all the separate components to connect) selection of Tuner/Tape/CD/AUX-VCR
Underneath is the SANSUI INTEGRATED AMPLIFIER Bass Boost System with the 3 Band Graphic Equalizer selection and Balance, Phones plug and Motorized Volume wheel...but reads MS 5900
Is this system a good one worth keeping? Your help greatly appreciated so I may decide wether to sell it or keep it! Thanks in advance.
