Easy guys and girls,
So at my workplace they found an old broken record player, and I had an idea to see if I could turn it into an oversized portable bluetooth speaker as a lil lockdown project.
The record player --
So basically my plan was to cut the front section off of the player (the part closest in the photo), and use that to create the speaker.
As I don't have a whole lot of equipment or knowledge to put the thing together, I was planning on using one of the WONDOM amp boards (
https://store.sure-electronics.com/product/AA-JA32151v2), as they have a separate battery board and another board with an aux input.
Obviously this still leaves me needing a speaker driver.. I am a music producer and DJ that plays Drum n Bass [Dance Music], so I'm after something with a semi decent low end response [aware size of speaker will be a factor], and I want it to be loud.
Any help or advice or just general 'dont do it, the enclosure will sound poop' appreciated.
