Hi, and thank you.
I used the word ‘sub’ very, very loosely. Too loosely I think, but was implying the end product, hopefully.
Monacor SP-167C
____.monacor.de/typo3/index.php?id=75&artid=1869&spr=EN&typ=u
I appreciate they’re not the best speakers in the world, by far, its just that I’ve them lying about so thought I’d use them and they’re going to offer some bass reinforcement to what I’ve got at the moment – which isn’t anything! (4x130mm).
Other wise I’ve got a 10” generic ‘proper’ sub (no stats)
Or
Monacor Predator-6/4:
____.monacor.de/typo3/index.php?id=75&artid=4913&spr=EN&typ=u
Impedance (Z) 4Ω
Resonant frequency (fs) 66Hz
Max. frequency range f3-2,500Hz
Music power 180WMAX
Power rating (P) 100WRMS
SPL (1W/1m) 91dB
Suspension compl. (Cms) 0.47mm/N
Moving mass (Mms) 12.4g
Mech. Q factor (Qms) 4.97
Electr. Q factor (Qes) 0.45
Total Q factor (Qts) 0.41
Equivalent volume (Vas) 10.6 l
DC resistance (Re) 3.15Ω
Force factor (BxL) 6.0Tm
Voice coil induct. (Le) 0.4mH
Voice coil diameter Ø 25mm
Voice coil former Kapton
Linear excursion (XMAX) ±3.75mm
Eff. cone area (Sd) 127cm2
Magnet weight 20oz.
Weight 1.55kg
Ideally I’m looking a cabinet size around 46x30x15cm (20.70L) so not much to play with at all.
Would i be best with the single 10" or trying an isobaric?
