Y
yammy750
I have a RX-750 Yamaha, I think everything is hooked up alright, but I do wish there were more EQ settings to mess around with! I also have a BBE Sound restore enhancer, I cant seem to figure out if its working or not, the lights do turn off and on. I remember before with my old unit I used Tape2 Monitor for the BBE. I cant remember what I plugged it into on this Yammy, I would have to pull all of my stuff out to see. Would any of you know what I am trying to say here?
MDS
I think you said:
1. I bought a Yamaha RX-V750.
2. I wish there were more EQ settings.
3. I have a BBE, but don't know if it's working.
4. I used to use tape 2 monitor for the BBE but don't know where it is connected on the new Yamaha.
So is there a question in there? If the BBE is an eq of some sort, you won't be able to use it the way you did before. Very few, if any, receivers nowadays include tape2 monitor loops.
