Yes, The rated nominal impedance, on the back of the speaker, is usually the lowest point at which a speaker will go. All good receivers will play down to 4 ohms easily. If your receiver has an impedance switch, this website will tell you to leave it set to the 8 ohms setting. Always, and just make sure your receiver or amplifier has plenty of ventilation
