Well, the difference in volume between your speaker driven at 300W and 30W is 10db. 60W (which you are closer to) would be -8db from 300W.
Specifically, with 93db sensitivity, you will get 108db at 50W at 1m before you add in room accentuation.
I suspect you will be fine, though if you want to get louder than an actual jackhammer, you could add more power.
I'm not a big CV fan, but knock yourself out.
*edit* It looks like the CV is 300W peak, not RMS: so it's not clear that you will see much sustained volume difference regardless.
