allen_in_texas
I live in central Texas, where it's hot and moderately humid. I also do not use AC. Is there anything I need to consider when purchasing and setting up my first audio system?
shadyJ
Speaker of the House
Staff member
A/C is for sissies.
Humidity will shorten the life of your electronic components, you have to expect that. Heat will shorten their life as well. They aren't doing your speakers any favors either, but the speakers will probably be fine for some time. A dry cool place is always the best conditions for electronics.
lsiberian
lsiberian
Why do you not use A/C? Do you at least use a fan with cold towels?
lsiberian
lsiberian
A/C is for sissies.
And people who don't want to die from heat related illness which is serious business down here in Texas.
Pyrrho
Pyrrho
A/C is for sissies.
That is what he said: sissies.;)
fuzz092888
fuzz092888
I've had my A/C going since about April. My apartment is great in the winter, but hell in the spring and summer because it retains heat like crazy. Plus gets a lot of direct sunlight all morning through midday. Add that to the heat generated by the amplifiers and TV/projector and I'd hit 85-90 in here (with an outside temp of 80) no problem and it's not that I'm even that hot, but I know the heat and humidity from not having it on would kill my stuff. General rule of thumb for me is that whatever my desk thermometer reads, the entertainment stand amplifier shelves will be, at minimum 10 degrees higher and that's with 7-200mm fans.
Actran
Heat index of 104 F down here today. I'll keep my A/C even if it does come with a "sissy" tag.
As for the electronics, I would actually be a little worried about running them repeatedly in a 85 to 100 F ambient environment. At the least, take the fan suggestion.
allen_in_texas
My electric bill last month was $8, which I split with my housemate. AC is a fine treat sometimes, but generally I hate the feeling of being trapped inside a bubble. A lot of folks I know who use AC every day seem to be afraid of going outside for a few minutes, and I hate listening to them go on and on about how hot it is outside.
Evaporative cooling works well where water readily evaporates, but it's a little too humid for that here. The heat really doesn't bother me unless I start spending too much time in AC.
ImcLoud
ImcLoud
I can not live with out A/C, literally, thats my job so with out it I can't live,,,
allen_in_texas
allen_in_texas
Yes, I figured a fan would be good. I wasn't sure if there'd be any issues with electromagnetic noise from the fan.
Pyrrho
Pyrrho
I did? I did. I need to stop multi-tasking, I'm terrible at it.
If it makes you feel any better, studies have shown that people are generally very bad at it, yet they often imagine that they are good at it. Just do an online search for multitasking if you wish to look at the data on this subject.
Pyrrho
Pyrrho
The biggest issue with using a fan is from hearing the fan itself. Otherwise, it is a good thing for your equipment.
ParadigmDawg
ParadigmDawg
I'm in Fort Worth, I keep my house at 71 degrees at all times. I am not afraid to go outside because of the heat. I cycle in the heat almost every day. 103 yesterday when I was on a road ride.
But...when I am in my house, I want to be cold, same when I'm in my car.
You never know how electronics are going to play out in heat/cold/moisture. I have a plasma outside and I planned on having to replace it every year or so. It has been going strong for over 4 years now.
