A very nice review site is
https://diyaudioheaven.wordpress.com that have measurements of the headphones, and for those using glasses, even the frequency response of using thin as well as thick arm (temple) glasses. For most headphone reviews he also test them with various pads.
Below is a review of the DT 1990 Pro (only 250 Ohm available), and in the review is there is a comparison with the DT 990 (I've never tried them). I've the DT 1990 myself and like them much better than the DT 880 Edition 250 Ohm that I've had for a decade. I also have the DT 1770 Pro (only 250 Ohm available), closed back, that I also like, but I use them mostly for mic duties or to have some sound isolation. Those headphones might be over your budget, though, but local prices varies quite a bit.
The DT 1990 and DT 1770 are fairly sensitive so easy to drive, noticeable more than my DT 880 Edition, and the DT 990 is similar going by specs.
back to Beyerdynamic back to measurements home published: Jul-16-2017, updated: Oct-03-2021 NO SMOOTHING is applied to the shown plots. Most measurement sites have some smoothing applied which ‘iro…
back to Beyerdynamic back to measurements home published: Jul-16-2017, updated: Feb-24-2020 NO SMOOTHING is applied to the shown plots. Most measurement sites have some smoothing applied which ‘iro…
back to Beyerdynamic back to measurements home published: Feb-28-2015, updated: Apr-17-2022 NO SMOOTHING is applied to the shown plots. Most measurement sites have some smoothing applied which R…
