Headphone automatic muting of speakers - block?
Bandolero
Would like to work around automuting of speakers when headphones are used, Yamaha RX-V571. Any help appreciated!
everettT
everettT
Buy a separate headphone amp and use the analog output. The Yamaha uses a shared volume control chip so you can't use both at the same time IIRC. What headphones are you using?
Yes, that is his only solution.
Bandolero
Tks for info, using Bose Quiet Comfort 25 headphones
everettT
everettT
Yeah the only other option is purchasing a Bluetooth adapter for the headphone and a transmitter for the audio output, but IMHO a headphone amp would serve you better, even a portable one since your headphones are easy load to drive.
