mfabien: Same question here - I don't why they're not updating their SA8300 software. I talked to the local cable office here and they did not know
Aaron:
"So they say that the HDMI port is active, and I noticed that when I first plug in the HDMI cable it s
displays picture for a second or so before witching to that message. Does anyone know why my projector's port might not be properly communicating the HDCP authentication to the 8300HD? And Time Warner says they don't support projector connections, so I can't ask them for support.
My
HDMI cable is 10' in length, I didn't think that was too long.
Maybe I'll
send my problem to BenQ, see if they've seen something like it before."
1.
The picture display for a second or so...This is the identical situation that happened in my case...
2.
Ten-foot HDMI cable? What did that cost you, about $200.00
3. ...
problem to BenQ - hopefully, they'll be able to help!
Just another thought on TW: did you consider calling the number that you'd normally use to contact the local cable office for a routine service call? They may give you a different answer than what the main TW office gave in their email reply to you!!!
I still have a hunch that the HDMI service is not available; however, if it is, the only other item I can think of to check would be in the
setup menu for your projector. I'm light year's away from being an expert in these areas so these are just some thoughts on where I'd look to resolve the problem..
-GeorgeM
